While installing libgtk2.0-dev i'm receiving following error:
Reading package lists... Done
Building dependency tree
libgtk2.0-dev : Depends: libglib2.0-dev (>= 2.27.3) but it is not going to be installed
Depends: libgdk-pixbuf2.0-dev (>= 2.21.0) but it is not going to be installed
Depends: libpango1.0-dev (>= 1.20) but it is not going to be installed
Depends: libatk1.0-dev (>= 1.29.2) but it is not going to be installed
Depends: libcairo2-dev (>= 1.6.4-6.1) but it is not going to be installed
I tried lots of things like -f flag, synaptic, install them individually , install all dependency at once but everything failed.
Is libgtk2.0-dev is not supported on ubuntu 16.04 ?
EDIT:
output of apt-cache policy libgtk2.0-dev libglib2.0-dev
libgtk2.0-dev:
Installed: (none)
Candidate: 2.24.30-1ubuntu1
Version table:
2.24.30-1ubuntu1 500
500 http://mirror.dhakacom.com/ubuntu-archive xenial/main amd64 Packages
libglib2.0-dev:
Installed: (none)
Candidate: 2.48.0-1ubuntu4
Version table:
2.48.0-1ubuntu4 500
