I'm trying to install clutter-1.26.0 as a prerequisite for other things. When I run ./configure it gets held up here:
configure: error: Package requirements (cogl-1.0 >= 1.21.2 cogl-path-1.0 cairo-gobject >= 1.14.0 gio-2.0 >= 2.44.0 atk >= 2.5.3 pangocairo >= 1.30 cogl-pango-1.0 json-glib-1.0 >= 0.12.0 gdk-3.0 wayland-cursor wayland-client xkbcommon x11 xext xdamage xcomposite >= 0.4 xi) were not met:
Requested 'cogl-1.0 >= 1.21.2' but version of Cogl is 1.16.2
No package 'cogl-path-1.0' found
Requested 'cairo-gobject >= 1.14.0' but version of cairo-gobject is 1.13.1
No package 'cogl-pango-1.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables CLUTTER_DEPS_CFLAGS
and CLUTTER_DEPS_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
I have a newer version cogl installed (cogl-1.22.2), but it doesn't seem to recognize it. If I figure this out I assume it will be a similar solution for the cairo-gobject problem. Do I need to install cogl-1.22.2 in the same directory as clutter-1.26.0? Or how can I get this installer to point to the correct cogl version?
