Please excuse me this is all virgin territory to me. Right I have Ubuntu 16.04 so I've been installing emus for it snes,nes,mega drive,etc. Well now I want to use my ps3 controller to play them. I got bluez-tools extracted the files but now how would I go about installing it and setting it up to use.Thanks in advance people hope you can help
Asked
Active
Viewed 9,324 times
I needed to install the bluez-5.43 to get around bugs in the default bluez-5.37 when using bluetoothctl from scripts.
You could probably install the binary version from Zesty, but my experience is that you often run into other dependencies.
I just install the deb-src package from Zesty. You probably need to install other dependencies too, here is what I had to do.
sudo apt-get install debhelper dh-autoreconf flex bison libdbus-glib-1-dev libglib2.0-dev libcap-ng-dev libudev-dev libreadline-dev libical-dev check dh-systemd libebook1.2-dev
wget https://launchpad.net/ubuntu/+archive/primary/+files/bluez_5.43.orig.tar.xz
wget https://launchpad.net/ubuntu/+archive/primary/+files/bluez_5.43-0ubuntu1.debian.tar.xz
wget https://launchpad.net/ubuntu/+archive/primary/+files/bluez_5.43-0ubuntu1.dsc
tar xf bluez_5.43.orig.tar.xz
cd bluez-5.43
tar xf ../bluez_5.43-0ubuntu1.debian.tar.xz
debchange --local=~lorenzen 'Backport to Xenial'
debuild -b -j4
cd ..
sudo dpkg -i *.deb
For an explanation of what is happening here, please consult
https://askubuntu.com/a/771272/655086
Peter Lorenzen
- 151
You don't need the extracted file (unless you're installing a particular version or the latest) as you can install from the repositories with the following command:
sudo apt install bluez-tools
Now simply use it.
George Udosen
- 37,534
