I am using Ubuntu 12.04. I can't install or upgrade any package I have:
apt-get install traceroute
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
linux-generic : Depends: linux-headers-generic (= 3.2.0.76.90) but 3.2.0.77.91 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
If I try -f, I'm told /boot is full:
apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
linux-headers-3.2.0-74 linux-image-3.2.0-74-generic linux-headers-3.2.0-74-generic
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
linux-generic linux-headers-generic linux-image-3.2.0-121-generic linux-image-generic
Suggested packages:
fdutils linux-doc-3.2.0 linux-source-3.2.0 linux-tools
The following NEW packages will be installed:
The following packages will be upgraded:
linux-generic linux-headers-generic linux-image-generic
3 upgraded, 1 newly installed, 0 to remove and 203 not upgraded.
10 not fully installed or removed.
Need to get 0 B/38.8 MB of archives.
After this operation, 151 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: error processing /var/cache/apt/archives/linux-image-3.2.0-121-generic_3.2.0-121.164_amd64.deb (--unpack):
failed in write on buffer copy for backend dpkg-deb during `./boot/vmlinuz-3.2.0-121-generic': No space left on device
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.2.0-121-generic /boot/vmlinuz-3.2.0-121-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.2.0-121-generic /boot/vmlinuz-3.2.0-121-generic
My /boot size:
/dev/sda1 92M 85M 1.9M 98% /boot
ls -ll
total 76775
-rw------- 1 root root 2884358 Apr 11 2012 System.map-3.2.0-23-generic
-rw------- 1 root root 2897962 Dec 9 2014 System.map-3.2.0-74-generic
-rw------- 1 root root 2898003 Dec 16 2014 System.map-3.2.0-75-generic
-rw------- 1 root root 2898466 Jan 13 2015 System.map-3.2.0-76-generic
-rw-r--r-- 1 root root 791023 Apr 11 2012 abi-3.2.0-23-generic
-rw-r--r-- 1 root root 796535 Dec 9 2014 abi-3.2.0-74-generic
-rw-r--r-- 1 root root 796535 Dec 16 2014 abi-3.2.0-75-generic
-rw-r--r-- 1 root root 796597 Jan 13 2015 abi-3.2.0-76-generic
-rw-r--r-- 1 root root 140279 Apr 11 2012 config-3.2.0-23-generic
-rw-r--r-- 1 root root 140790 Dec 9 2014 config-3.2.0-74-generic
-rw-r--r-- 1 root root 140790 Dec 16 2014 config-3.2.0-75-generic
-rw-r--r-- 1 root root 140790 Jan 13 2015 config-3.2.0-76-generic
drwxr-xr-x 3 root root 7168 Feb 1 2015 grub
-rw-r--r-- 1 root root 14177627 Apr 9 2014 initrd.img-3.2.0-23-generic
-rw-r--r-- 1 root root 14232258 Dec 11 2014 initrd.img-3.2.0-74-generic
-rw-r--r-- 1 root root 14233553 Feb 1 2015 initrd.img-3.2.0-75-generic
drwx------ 2 root root 12288 Nov 21 2013 lost+found
-rw-r--r-- 1 root root 176764 Nov 27 2011 memtest86+.bin
-rw-r--r-- 1 root root 178944 Nov 27 2011 memtest86+_multiboot.bin
-rw------- 1 root root 4965840 Apr 11 2012 vmlinuz-3.2.0-23-generic
-rw------- 1 root root 4990768 Dec 9 2014 vmlinuz-3.2.0-74-generic
-rw------- 1 root root 4991088 Dec 16 2014 vmlinuz-3.2.0-75-generic
-rw------- 1 root root 4991856 Jan 13 2015 vmlinuz-3.2.0-76-generic
I tried the solution here and other purge old kernels solutions but I got the following error:
$ uname -r
3.2.0-75-generic
$dpkg --list 'linux-image*' | grep ^ii
ii linux-image-3.2.0-23-generic 3.2.0-23.36 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-74-generic 3.2.0-74.109 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii linux-image-3.2.0-75-generic 3.2.0-75.110 Linux kernel image for version 3.2.0 on 64 bit x86 SMP
$ apt-get remove linux-image-3.2.0-74-generic
Any help please?
Edit:
I tried the solution here and removed old kernels manually, but now I get a different dependcy issue:
apt-get install -f
Generating grub.cfg ...
Warning: Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.
Found linux image: /boot/vmlinuz-3.2.0-121-generic
Found initrd image: /boot/initrd.img-3.2.0-121-generic
Found linux image: /boot/vmlinuz-3.2.0-76-generic
Found initrd image: /boot/initrd.img-3.2.0-76-generic
Found linux image: /boot/vmlinuz-3.2.0-75-generic
Found initrd image: /boot/initrd.img-3.2.0-75-generic
Found memtest86+ image: /memtest86+.bin
done
Setting up linux-image-generic (3.2.0.121.136) ...
Setting up linux-headers-generic (3.2.0.121.136) ...
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 3.2.0.76.90); however:
Version of linux-image-generic on system is 3.2.0.121.136.
linux-generic depends on linux-headers-generic (= 3.2.0.76.90); however:
Version of linux-headers-generic on system is 3.2.0.121.136.
dpkg: error processing linux-generic (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
linux-generic
and current kernel is still "3.2.0-75-generic"
