Recently, after a sudden power failure, my 1tb hard drive (/dev/sda1) failed and will not mount. It says, Error mounting /dev/sda1 at /media/zangar_/4b84d62b-520d-408e-addc-7a2bf52cc4e3: Command-line ``mount -t "ext4" -o "uhelper=udisks2,nodev,nosuid" "/dev/sda1" "/media/zangar_/4b84d62b-520d-408e-addc-7a2bf52cc4e3"' exited with non-zero exit status 32: mount: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error
   `In some cases useful info is found in syslog - try
   dmesg | tail or so.`
I tried e2fsck but it asks me to Get a newer version of e2fsck! Then, I looked at all the other posts about updating e2fsck (here and here.) These answers did not work for me. My problem!
Any help is greatly appreciated, as i have time sensitive documents in the unmountable drive.
Zangar
  • 140
Using a live CD/DVD/USB seems like a workaround that may not be always applicable.
I believe that the correct answer how to have e2fsck updated is to compile latest version from the sources.
  1. Download the latest version (1.44.3) from http://e2fsprogs.sourceforge.net/ and unpack in a directory and cd into it.
  2. According to the INSTALL document:
     mkdir build; cd build
     ../configure
     make
     sudo make install
  3. Check that you have new version now:
     $ e2fsck -V
     e2fsck 1.44.3 (10-July-2018)
     Using EXT2FS Library version 1.44.3, 10-July-2018
Note: you may need to install compiler and tools with apt get install gcc.
UPDATE 09/2020: Above link is official ext2fs informational microsite (non https protected), lastest sources are securely hosted on https://sourceforge.net/projects/e2fsprogs/. BTW author announced: "All users of e2fsprogs are urged to upgrade to the 1.45.6 version as soon as possible".
VasekCh
  • 221
Boot to a Ubuntu Live DVD/USB 16.10 (prefer DVD). It must be 16.10 or higher.
Open a terminal and type sudo fsck -f /dev/sda1.
Now you may be able to mount the drive as normal.
heynnema
  • 73,649
