So in the last time I kinda' broke my Ubuntu server and I'm getting the following error, I want to say that I deleted some of the libjpeg8:i386 things and now I can't install any packages!
root@s1:~# apt-get install php-apc
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies:
libgd3:i386 : Depends: libjpeg8:i386 (>= 8c) but it is not going to be installed
libgphoto2-6:i386 : Depends: libjpeg8:i386 (>= 8c) but it is not going to be installed
libsane:i386 : Depends: libjpeg8:i386 (>= 8c) but it is not going to be installed
libtiff5:i386 : Depends: libjpeg8:i386 (>= 8c) but it is not going to be installed
libv4lconvert0:i386 : Depends: libjpeg8:i386 (>= 8c) but it is not going to be installed
php-apc : Depends: php5-apcu but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
root@s1:~# apt-get -f install
Correcting dependencies... Done
The following additional packages will be installed:
libjpeg8:i386
The following NEW packages will be installed:
libjpeg8:i386
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
11 not fully installed or removed.
Need to get 0 B/2,188 B of archives.
After this operation, 26.6 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 247834 files and directories currently installed.)
Preparing to unpack .../libjpeg8_8c-2ubuntu8_i386.deb ...
Unpacking libjpeg8:i386 (8c-2ubuntu8) ...
dpkg: error processing archive /var/cache/apt/archives/libjpeg8_8c-2ubuntu8_i386.deb (--unpack):
trying to overwrite shared '/usr/share/doc/libjpeg8/copyright', which is different from other instances of package libjpeg8:i386
