I've recently setup a Gameserver (that requires a MySQL, as well as a bunch of time to fool with it) and i REALLY didn't want to do this through a terminal.
Well, The answer was obvious Install phpMyAdmin. Or, perhaps not. This is a clean install, One of the first things i did was to firstly: 1) Install Apache2 2) Install mysql-server 3) Install needed PHP components listed for PHPMyAdmin. 4) Install PhpMyAdmin. 5) Get hit by a brickwall, called PhpMyAdmin.
It appears to have installed correctly, I've tested Apache with both its own index.html as well as a .php, it can find them, no issues here.
Attempt A) I have tried creating a link with: " sudo ln -s /usr/share/phpmyadmin /var/www/html " Result = No Luck.
Attempt B) Inserting the line: " Include /etc/phpmyadmin/apache.conf " into "/etc/apache2/apache2.conf" Result = No Luck.
Attempt C) Restart server Result = No Luck.
Attempt D) Check that MySQL is working (Incase for some odd reason that was it.) Status = it's working. Result = No Luck.
Attempt E) When in doubt, Re-configure PhpMyAdmin? Result = No Luck.
Attempt F) When in doubt, Reinstall PhpMyAdmin? Result = No Luck.
Attempt G) "Go to sleep after banging my head against a wall for 17 hours." Result = Headache.
Attempt H) Finally, Ask others that hopefully know a thing or two more then me. Result = We shall see.
Regards, Tau.
Tau
