I would like to set up a git server with apt-get. Here is how it went:
# apt-get install git-core
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  linux-image-4.4.0-53-generic
Use 'apt autoremove' to remove it.
The following packages will be REMOVED:
  linux-image-extra-4.4.0-53-generic linux-image-extra-4.4.0-57-generic
The following NEW packages will be installed:
  git-core
0 upgraded, 1 newly installed, 2 to remove and 37 not upgraded.
8 not fully installed or removed.
Need to get 0 B/1,464 B of archives.
After this operation, 315 MB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 294882 files and directories currently installed.)
Removing linux-image-extra-4.4.0-53-generic (4.4.0-53.74) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.0-53-generic /boot/vmlinuz-4.4.0-53-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.4.0-53-generic /boot/vmlinuz-4.4.0-53-generic
update-initramfs: Generating /boot/initrd.img-4.4.0-53-generic
E: /usr/share/initramfs-tools/hooks/plymouth failed with return 1.
update-initramfs: failed for /boot/initrd.img-4.4.0-53-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-extra-4.4.0-53-generic (--remove):
 subprocess installed post-removal script returned error exit status 1
Removing linux-image-extra-4.4.0-57-generic (4.4.0-57.78) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.0-57-generic /boot/vmlinuz-4.4.0-57-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.4.0-57-generic /boot/vmlinuz-4.4.0-57-generic
update-initramfs: Generating /boot/initrd.img-4.4.0-57-generic
update-initramfs: failed for /boot/initrd.img-4.4.0-57-generic with 1.
dpkg: error processing package linux-image-extra-4.4.0-57-generic (--remove):
When I manually purge # apt-get remove linux-image-extra-4.4.0-53-generic linux-image-extra-4.4.0-57-generic -y, here was the result:
0 upgraded, 0 newly installed, 2 to remove and 37 not upgraded.
7 not fully installed or removed.
(Reading database ... 293795 files and directories currently installed.)
depmod: FATAL: could not load /boot/System.map-4.4.0-53-generic: No such file or directory
WARNING: missing /lib/modules/4.4.0-53-generic
Ensure all necessary drivers are built into the linux image!
depmod: ERROR: could not open directory /lib/modules/4.4.0-53-generic: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
This issue has annoyed me for long. What should I do? Thank you very much!
UPDATE on 14 Feb 2017 02:26UTC: I have tried to # apt-get install --reinstall option as suggested but it returned errors as below:
# apt-get install --reinstall linux-image-extra-4.4.0-53-generic linux-image-extra-4.4.0-57-generic && sudo apt-get purge linux-image-extra-4.4.0-53-generic linux-image-extra-4.4.0-57-generic
The following additional packages will be installed:
Suggested packages:
  fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
  linux-headers-4.4.0-53-generic
0 upgraded, 1 newly installed, 2 reinstalled, 0 to remove and 37 not upgraded.
Need to get 0 B/94.3 MB of archives.
After this operation, 57.1 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Selecting previously unselected package linux-image-4.4.0-53-generic.
(Reading database ... 293804 files and directories currently installed.)
Preparing to unpack .../linux-image-4.4.0-53-generic_4.4.0-53.74_amd64.deb ...
Done.
Unpacking linux-image-4.4.0-53-generic (4.4.0-53.74) ...
Selecting previously unselected package linux-image-extra-4.4.0-53-generic.
Preparing to unpack .../linux-image-extra-4.4.0-53-generic_4.4.0-53.74_amd64.deb ...
Unpacking linux-image-extra-4.4.0-53-generic (4.4.0-53.74) over (4.4.0-53.74) ...
Selecting previously unselected package linux-image-extra-4.4.0-57-generic.
Preparing to unpack .../linux-image-extra-4.4.0-57-generic_4.4.0-57.78_amd64.deb ...
Unpacking linux-image-extra-4.4.0-57-generic (4.4.0-57.78) over (4.4.0-57.78) ...
Setting up linux-image-extra-4.4.0-62-generic (4.4.0-62.83) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.0-62-generic /boot/vmlinuz-4.4.0-62-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.4.0-62-generic /boot/vmlinuz-4.4.0-62-generic
update-initramfs: Generating /boot/initrd.img-4.4.0-62-generic
update-initramfs: failed for /boot/initrd.img-4.4.0-62-generic with 1.
dpkg: error processing package linux-image-extra-4.4.0-62-generic (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-generic:
 linux-image-generic depends on linux-image-extra-4.4.0-62-generic; however:
  Package linux-image-extra-4.4.0-62-generic is not configured yet.
dpkg: error processing package linux-image-generic (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic:
 linux-generic depends on linux-image-generic (= 4.4.0.62.65); however:
  Package linux-image-generic is not configured yet.
dpkg: error processing package linux-generic (--configure):
dpkg: dependency problems prevent configuration of linux-generic-lts-vivid:
 linux-generic-lts-vivid depends on linux-generic; however:
  Package linux-generic is not configured yet.
dpkg: error processing package linux-generic-lts-vivid (--configure):
Setting up linux-image-4.4.0-57-generic (4.4.0-57.78) ...
No apport report written because the error message indicates its a followup error from a previous failure.
                                                    No apport report written because MaxReports is reached already
                                  Running depmod.
update-initramfs: deferring update (hook will be called later)
Not updating initrd symbolic links since we are being updated/reinstalled
(4.4.0-57.78 was configured last, according to dpkg)
Not updating image symbolic links since we are being updated/reinstalled
Examining /etc/kernel/postinst.d.
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.4.0-57-generic.postinst line 1052.
dpkg: error processing package linux-image-4.4.0-57-generic (--configure):
 subprocess installed post-installation script returned error exit status 2
                                                              Setting up linux-image-4.4.0-53-generic (4.4.0-53.74) ...
Running depmod.
(4.4.0-53.74 was configured last, according to dpkg)
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-4.4.0-53-generic.postinst line 1052.
dpkg: error processing package linux-image-4.4.0-53-generic (--configure):
                                                              dpkg: dependency problems prevent configuration of linux-image-extra-4.4.0-53-generic:
 linux-image-extra-4.4.0-53-generic depends on linux-image-4.4.0-53-generic; however:
  Package linux-image-4.4.0-53-generic is not configured yet.
dpkg: error processing package linux-image-extra-4.4.0-53-generic (--configure):
dpkg: dependency problems prevent configuration of linux-image-extra-4.4.0-57-generic:
 linux-image-extra-4.4.0-57-generic depends on linux-image-4.4.0-57-generic; however:
  Package linux-image-4.4.0-57-generic is not configured yet.
                                            dpkg: error processing package linux-image-extra-4.4.0-57-generic (--configure):
 linux-image-generic
 linux-generic
Any help?
Have you deleted the kernel files manually? Try reinstalling with
sudo apt-get install --reinstall linux-image-extra-4.4.0-53-generic linux-image-extra-4.4.0-57-generic && sudo apt-get purge linux-image-extra-4.4.0-53-generic linux-image-extra-4.4.0-57-generic
This will first reinstall the package (so that all files are present), and then purge the package. This is the normal fix when files are missing.
vidarlo
  • 23,497
