In terminal I can rename a single file that starts with a dash, i.e.
mv ./-file file
I can also rename all files in a directory that start with a dash, i.e.
for f in ./-*; do rename 's/-//' "$f"; done
However, how can I do this recursively. I have tried using the find command, the rename command, and a recursive for loop. By the way, a lot of the file names have more than one dash. I would only want to remove the first dash. Thanks!
jbrock
  • 3,417
Using find and rename:
find . -iname '-*' -execdir rename -n 's:./-:./:' {} +
find . -iname '-*' matches all filenames beginning with a -, and then -execdir ... {} + runs the command with those filenames as arguments, after cding to the directory containing the files. This means that the command arguments always has filenames of the form ./-foo. Then it's easy to just match the - after the ./ in a regex.
muru
  • 207,228
I guess this should work as well
for i in $(find . -iname '-*') ; do mv $i $(echo $i | sed -e "s/-//"); done
nairoby
