How do I start Telegram messenger from the command line?
I have tried "telegram", but it's not that.
I have installed Telegram via ppa: ppa:atareao/telegram.
Since you installed telegram from the PPA, it is likely installed in /opt. Probably under /opt/telegram. You should be able to launch it from the command-line by running:
/opt/telegram/Telegram
but if you wanted to make this easier you can create a symbolic link to /usr/local/bin like so:
sudo ln -s /opt/telegram/Telegram /usr/local/bin/telegram
you can then launch telegram with the command:
telegram
On Ubuntu 17.10, 18.04 and above, If you have installed using Ubuntu Software Manager, you can launch it using the following command in terminal:
telegram-desktop
if you want to start it minimized in tray use the following command (e.g you want to create an start up entry):
telegram-desktop -startintray
If you know where you installed your Telegram,
you can easily launch the script, see the example below (I installed it in directory named soft).
(base) user@user:~/soft/Telegram$ ls
Telegram Updater
(base) user@user:~/soft/Telegram$ ./Telegram
Voila, you have it running.
