When running:
sudo service plexmediaserver start
I receive this error:
~$ sudo service plexmediaserver start
Job for plexmediaserver.service failed because the control process exited with error code. See "systemctl status plexmediaserver.service" and "journalctl -xe" for details.
Here is the output for the systemctl status
● plexmediaserver.service - Plex Media Server for Linux
   Loaded: loaded (/etc/systemd/system/plexmediaserver.service; enabled; vendor
   Active: inactive (dead) (Result: exit-code) since Sun 2017-02-12 22:01:21 GMT
  Process: 3231 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_AP
Feb 12 22:01:16 UBUN2LP systemd[1]: Failed to start Plex Media Server for Linux.
Feb 12 22:01:16 UBUN2LP systemd[1]: plexmediaserver.service: Unit entered failed
Feb 12 22:01:16 UBUN2LP systemd[1]: plexmediaserver.service: Failed with result
Feb 12 22:01:21 UBUN2LP systemd[1]: plexmediaserver.service: Service hold-off ti
Feb 12 22:01:21 UBUN2LP systemd[1]: Stopped Plex Media Server for Linux.
Feb 12 22:01:21 UBUN2LP systemd[1]: plexmediaserver.service: Start request repea
Feb 12 22:01:21 UBUN2LP systemd[1]: Failed to start Plex Media Server for Linux.
Here is the output for journalctl -xe
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit plexmediaserver.service has failed.
-- The result is failed.
-- Subject: Unit plexmediaserver.service has finished shutting down
-- Defined-By: systemd
-- Unit plexmediaserver.service has finished shutting down.
-- Subject: Unit plexmediaserver.service has failed
I have tried re installing but receive this error every time.
I have also followed this guide and it made no difference.
Jack
  • 31
I wrote myself a little guide based on info that actually worked for me online. Hopefully it can help someone.
  • INSTALL PLEX
CREATE 'PLEX' FOLDER UNDRE PRIMARY USER E.G /home/ntuser/PLEX
WHEN ADDING LIBARY TO PLEX ADD UP TO .../.../PLEX
Install Plex Media Server Ubuntu 16.x and Later
Add the Plex repository GPG key and add Plex the plex repository, you can copy and paste the whole block into your SSH session
If you get the key is not found error then it may have changed name, find the .key file from here and replace it in the wget line
wget -O - http://shell.ninthgate.se/packages/shell.ninthgate.se.gpg.key | sudo apt-key add -
echo "deb http://shell.ninthgate.se/packages/debian jessie main" | sudo tee -a /etc/apt/sources.list.d/plex.list
sudo apt update
Install the Plex Media Server on Ubuntu 16.x and later
sudo apt install plexmediaserver -y
YOU HAVE TO INSTALL .DEB MANUALLY!!!! SEE INSTALL DKPG INSTALL
See if you can connect at http://ip.address:32400/web or http://ip.address:32400/manage/index.html#!/setup
Plex Media Server will autostart on boot ??
  • Fix Plex Permission Issues
If you are getting permission issues it is because Plex runs as its own user, there are two options: change permissions of the downloads folders or change the user Plex runs as – you can do both but option 1 should suffice.
If Plex isn’t showing your folder so you can add you videos then this will fix it.
To change permissions of your media folders, first add the plex user to your main user’s group
sudo usermod -aG ntuser plex
Then set the permissions of your media folders to 775 so your group (and the plex user member of that group) can execute files
sudo chmod -R 775 /path/to/media
Jack
  • 31
