15
I installed nextcloud on my raspberrypi 3 using this link. Everything is working pretty well except I don't like the UX of having all the extra storage space coming from the "External Storage" add-in, since it means that everyone now has to know to put all of their files in a designated folder.
It seems like I should just be able to tell nextcloud to use the external harddrive as the data-directory location (without the external storage add-in) and all will be well and good... and it seems like in theory that works fine. But, since it's installed as a snap, it seems like the snap doesn't have access to that part of my filesystem and thus it doesn't work.
I was wondering if anyone had any suggestions. Should I mount the harddrive inside the snap's writable area? Is it possible to give the snap access to the harddrive?
Matt
  • 153
A bug was logged against the Nextloud snap for this issue, with the solution given here. It's now a wiki entry as well.
To quickly summarize here: you're right, this should be possible, and it is. However, by default the Nextcloud snap doesn't have permission to access removable media (as mentioned in its README).
So, the steps given are:
  1. Connect the removable-media plug: sudo snap connect nextcloud:removable-media.
  2. Connecting that interface gives Nextcloud permission to access things in /media/, so you can edit /var/snap/nextcloud/current/nextcloud/config/config.php and make sure the datadirectory is pointing to the right place.
  3. Disable the snap: sudo snap disable nextcloud
  4. Move (or copy) the current data directory to the new location: sudo mv /var/snap/nextcloud/common/nextcloud/data /media/my/new/data.
  5. Re-enable the snap: sudo snap enable nextcloud.
Now you don't need to bother with the external media solution: all of Nextcloud's data will be there.
Note that this only covers the raw data (e.g. files) hosted by Nextcloud. The database and apps are still in /var/snap/nextcloud/current/. I suggest you leave them there.
Note: if you have issues with the Nextcloud snap, you can log a bug against it.
theMayer
  • 103
kyrofa
  • 7,502
Use 'stop' instead of 'disable' otherwise you won't be able to edit config.php.
  1. Enable external storage for snap: sudo snap connect nextcloud:removable-media
  2. Stop nexcloud snap: sudo snap stop nextcloud
  3. Update storage location: sudo vim /var/snap/nextcloud/current/nextcloud/config/config.php
change data location:
'datadirectory' => '/media/storage/data',
  1. Move the data directory to the storage device: sudo mv /var/snap/nextcloud/common/nextcloud/data /media/storage/
  2. Start nextcloud snap: sudo snap start nextcloud
