I have a Technotrend CT2 4650. It worked perfectly on a Ubuntu 16.04.02, which was a upgrade from the previous LTS line as far as I remember. The USB module was dvb_usb_dvbsky.
Then my SSD crashed, and I reinstalled 16.04.02 the other day. It's not discovered anymore. It's shown in lsusb of course, but the module does not seem to initialize it:
Bus 001 Device 003: ID 0b48:3015 TechnoTrend AG
When I modprobe dvb_usb_dvbsky, this appears in dmesg:
[  175.468458] usbcore: registered new interface driver dvb_usb_dvbsky
I have tested the module on a PC running OpenSuSE, and the following turned up in dmesg:
[220841.422482] usb 1-2: new high-speed USB device number 9 using xhci_hcd
[220841.563158] usb 1-2: New USB device found, idVendor=0b48, idProduct=3015
[220841.563161] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[220841.563162] usb 1-2: Product: TechnoTrend USB2.0
[220841.563163] usb 1-2: Manufacturer: CityCom GmbH
[220841.563164] usb 1-2: SerialNumber: 20151107
[220843.006483] usb 1-2: dvb_usb_v2: found a 'TechnoTrend TT-connect CT2-4650 CI v1.1' in warm state
[220843.006543] usb 1-2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[220843.006557] DVB: registering new adapter (TechnoTrend TT-connect CT2-4650 CI v1.1)
[220843.007850] usb 1-2: dvb_usb_v2: MAC address: bc:ea:2b:65:04:ab
[220843.020459] i2c i2c-8: Added multiplexed i2c bus 9
[220843.020462] si2168 8-0064: Silicon Labs Si2168-B40 successfully identified
[220843.020463] si2168 8-0064: firmware version: B 4.0.2
[220843.023511] si2157 9-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[220843.030075] sp2 8-0040: CIMaX SP2 successfully attached
[220843.030085] usb 1-2: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
[220843.058431] Registered IR keymap rc-tt-1500
[220843.058529] input: TechnoTrend TT-connect CT2-4650 CI v1.1 as /devices/pci0000:00/0000:00:14.0/usb1/1-2/rc/rc0/input25
[220843.058616] rc rc0: TechnoTrend TT-connect CT2-4650 CI v1.1 as /devices/pci0000:00/0000:00:14.0/usb1/1-2/rc/rc0
[220843.058619] usb 1-2: dvb_usb_v2: schedule remote query interval to 300 msecs
[220843.058621] usb 1-2: dvb_usb_v2: 'TechnoTrend TT-connect CT2-4650 CI v1.1' successfully initialized and connected
[220843.058647] usbcore: registered new interface driver dvb_usb_dvbsky
[220849.365260] dvb_ca adapter 0: DVB CAM detected and initialised successfully
As far as I can remember, this is more or less what turned up on the previous Ubuntu install as well - I particularly remember seeing the initialization of the CAM...
I have tried insmodding the required modules manually, with no result.
This is what appears in dmesg when I plug the USB cable to the device, with relevant modules loaded:
[ 3285.678512] usb 1-1.1: new high-speed USB device number 6 using ehci-pci
[ 3285.776059] usb 1-1.1: New USB device found, idVendor=0b48, idProduct=3015
[ 3285.776065] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3285.776070] usb 1-1.1: Product: TechnoTrend USB2.0
[ 3285.776073] usb 1-1.1: Manufacturer: CityCom GmbH
[ 3285.776076] usb 1-1.1: SerialNumber: 20151107
Compared to OpenSuSE (and previous Ubuntu install) it's not much.
Any pointers are welcome.
vidarlo
  • 23,497
Upgrading to 4.8 fixed things. Turned out that the 4.4.0 kernel is too old.
vidarlo
  • 23,497
