I have a python script that gets messages from an MQTT server and parses them to display using libnotify. This works fine when I run it from a terminal, but when I run it using upstart I get no notification bubbles. I assume because it doesn't understand which X display and Xauthority file to use.
When I did something similar with cron I had to set it up as */10 * * * * DISPLAY=:0.0 XAUTHORITY=~/.Xauthority notify-send "Don't forget" "you're awesome" I assume I need to do something similar with upstart to make this work? Or is there a way to get libnotify to broadcast to all xscreens or somesuch?
Thanks for any advice or pointers
