At my university, I have a Xubuntu workstation, on which all my simulations and other scientific applications/calcs are run. When I am physically present in the office, I use the i3 window manager, which suits my keyboard-centric workflow.
When I need to connect my SP3 to my office workstation, there are occasions on which I need X-window support. I don't have admin access on staff machine, so installing nomachineNX/FreeNX/other NX variants is out. Even if I get ICT to do it on one machine, I can't connect from say, a library machine running win7.
I have tried the solution posted here Can I access Ubuntu from Windows remotely? . Although it worked for a few weeks when my workstation updated to a newer kernel and in another update xrdp also got updated, something broke, and systemd would not let xrdp service start. I then read online about the incompatibilities of systemd and xrdp. It also seems that there is a related project x11rdp-o-matic, which provides an automated configuration for directed sound/monitor config etc. But it looks like the maintainer of that project also abandoned this due to frustration with above-mentioned systemd issues.
I'd ideally like to connect to an i3 session if possible (or at-least have a reliable workaround for the xfce connection issues described above)
the content of the xrdp.service and xrdp-sesman.service files that control xrdp sessions does not seems to reflect the correct information about path locations for executable files and Environment. To solve the issue, we delete the xrdp.service and xrdp-sesman.service files from the /lib/systemd/system folder.
Reboot Ubuntu and check to insure that the xrdp service is running properly with the command sudo systemctl status xrdp and confirm that the service is marked as active.
This answer is in response to the question asked and is in no way intended to answer unrelated questions regarding broken packages.
Source:
http://c-nergy.be/blog/?p=8316
Elder Geek
  • 36,752
