Any time I try to install a package or upgrade using apt-get, I get the error below.
root@localhost# apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
Need to get 0 B/610 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up python-wheel (0.29.0-1) ...
Traceback (most recent call last):
File "/usr/bin/pycompile", line 35, in <module>
from debpython.version import SUPPORTED, debsorted, vrepr, \
File "/usr/share/python/debpython/version.py", line 24, in <module>
from ConfigParser import SafeConfigParser
ImportError: No module named 'ConfigParser'
dpkg: error processing package python-wheel (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: error processing package ipython (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
Setting up python-configparser (3.3.0r2-2) ...
dpkg: error processing package python-configparser (--configure):
Setting up python-pip (8.1.2-2ubuntu0.1) ...
dpkg: error processing package python-pip (--configure):
No apport report written because MaxReports is reached already
python-wheel
ipython
python-configparser
python-pip
