$ sudo apt-get install uuid-dev
Reading package lists... Done
Building dependency tree
uuid-dev : Depends: libuuid1 (= 2.27.1-6ubuntu3) but 2.27.1-6ubuntu3.1 is to be installed
Asked
Active
Viewed 6,658 times
You need downgrade your libuuid1 version from 2.27.1-6ubuntu3.1 to 2.27.1-6ubuntu3.
You can use apt-get to do a downgrade, refer to this answer.
sudo apt-get install <package-name>=<package-version-number> OR
sudo apt-get -t=<target release> install <package-name>
If you are using synaptic package manager, you can also just simply select the package (in your case, search and select libuuid1), and go to menu Package > Force Version.. to choose the version you would like to install, then click Apply.
Gary Wang
- 173
