I'm having a small problem. I've been trying to work Minecraft into working using Wine. Over the past few hours, I've been working with Java over and over (long story, I'll keep it relevant) and have finally come to an answer. I need to install Oracle Java, or Sun-JRE as more commonly known. I found this answer https://askubuntu.com/a/56119 and followed the instructions. I changed the file name where need-be in the commands for the newer version, placing the extracted file into /usr/lib/jvm but when I type this command:
sudo update-alternatives --config java
I am met with this:
There are 2 choices for the alternative java (providing /usr/bin/java).
  Selection    Path                                           Priority   Status
  0            /usr/lib/jvm/java-6-openjdk/jre/bin/java        1061      auto mode
  1            /usr/lib/jvm/java-6-openjdk/jre/bin/java        1061      manual mode
* 2            /usr/lib/jvm/java-7-openjdk-i386/jre/bin/java   1051      manual mode
Press enter to keep the current choice[*], or type selection number:
This confuses me, as I followed the steps in the answer linked previously by copy/pasting and editing for the file name. The name of the file I used is Linux x86 32.25 MB jre-7u2-linux-i586.tar.gz. The ls -ld command returned the following:
ls -ld /usr/lib/jvm/*
lrwxrwxrwx 1 root   root    14 2011-09-27 12:25 /usr/lib/jvm/default-java -> java-6-openjdk
lrwxrwxrwx 1 root   root    14 2011-10-22 01:14 /usr/lib/jvm/java-1.6.0-openjdk -> java-6-openjdk
lrwxrwxrwx 1 root   root    19 2011-10-21 19:24 /usr/lib/jvm/java-1.7.0-openjdk-i386 -> java-7-openjdk-i386
drwxr-xr-x 5 root   root   120 2011-12-16 02:35 /usr/lib/jvm/java-6-openjdk
drwxr-xr-x 3 root   root    60 2011-12-16 02:35 /usr/lib/jvm/java-7-openjdk-common
drwxr-xr-x 5 root   root   120 2011-12-16 02:35 /usr/lib/jvm/java-7-openjdk-i386
drwx------ 6 ubuntu ubuntu 240 2011-11-17 21:39 /usr/lib/jvm/jre1.7.0_02
Any help is appreciated, and thanks in advance.
Estel
  • 73
First of all, please add the correct permissions to the folder...
sudo chmod -R rwxr-xr-x /usr/lib/jvm/jre1.7.0_02
Next add JRE to the Java Alternatives
sudo update-alternatives --install /usr/bin/java java /usr/lib/jvm/jre1.7.0_02/bin/java 3;
And finaly, run the command:
edgerch
  • 364
