I have got a laptop on ubuntu 16.04 and I can't configure the ethernet card ... I don't have wifi and ethernet connexion... I believe that it is a atheros e2600 but I am not sure.
when I type modinfo alx I have this :
filename: /lib/modules/4.4.0-31-generic/kernel/drivers/net/ethernet/atheros/alx/alx.ko
license: GPL
description: Qualcomm Atheros(R) AR816x/AR817x PCI-E Ethernet Network Driver
author: Qualcomm Corporation, <nic-devel@qualcomm.com>
author: Johannes Berg <johannes@sipsolutions.net>
srcversion: 25B6ABE36E6CB50C1A7E6DF
alias: pci:v00001969d000010A0sv*sd*bc*sc*i*
alias: pci:v00001969d000010A1sv*sd*bc*sc*i*
alias: pci:v00001969d00001090sv*sd*bc*sc*i*
alias: pci:v00001969d0000E0A1sv*sd*bc*sc*i*
alias: pci:v00001969d0000E091sv*sd*bc*sc*i*
alias: pci:v00001969d00001091sv*sd*bc*sc*i*
depends: mdio
intree: Y
vermagic: 4.4.0-31-generic SMP mod_unload modversions'
If I do lspci -nn I have this:
02:00.0 Network controller [0280]: Inter Corporation Device [8086:24fb] (rev 10)
03:00.0 Ethernet controller [0200]: Qualcomm Atheros Device [1969:e0b1] (rev 10)
I have download linux-firmware_1.127.22_all.deb and installed doing: sudo dpkg -i linux-firmware____.deb
I have tried this solution as weel: [Is there any way to install Atheros e2400 drivers?
without success either.
I added :
enter code #define ALX_DEV_ID_E2600 0xe0b1
in reg.h
and :
{ PCI_VDEVICE(ATTANSIC, ALX_DEV_ID_E2600), .driver_data = ALX_DEV_QUIRK_MSI_INTX_DISABLE_BUG },
in main.c
but when I do
`make -C /lib/modules/$(uname -r)/build M=$(pwd) modules
(when I am in /ubuntu-xenial/drivers/net/ethernet/atheros/alx, is that where I should do it ?) I don't have any error. (make entering directory /usr/src/linux-headers-4.4.0-31-generic etc ... and then make leaving directory same one)
but when I do :
sudo make -C /lib/modules/$(uname -r)/build M=$(pwd) modules_install
I have an error: "no such file: bss_file.c:178 sign-file: certs/signing_key.pem no such file or directory".
any Idea ?
Regards,
