25
Is it possible to have a samba share read only for guests, and read write for authenticated users?
If I put guest ok on an share then I am not prompted for a password, and effectively logged as guest with read only rights. But I want to be authenticated so that I can also write.
Could anyone provide a sample smb share stanza to achieve this?
yannisf
  • 351
Edit /etc/samba/smb.conf
# command line
sudo -e /etc/samba/smb.conf
# graphical
gksu gedit /etc/samba/smb.conf
Add in the write list paramter to your share definition, add in your list of users allowed write access.
write list = user1 user2 user3
You can use read list as well
read list = guest, nobody
So ...
[share]
comment = Ubuntu Share
path = /your/samba/share
browsable = yes
guest ok = yes
read only = yes
create mask = 0755
If you need finer grain of control, you can use acl (access control lists) on the server.
Charles Green
  • 21,859
Panther
  • 104,528
10
Read only parameter is a Boolean value, so this should be more like one of the following:
[share]
browsable = yes
guest ok = yes
read only = no
read list = guest nobody
create mask = 0755
[share]
browsable = yes
guest ok = yes
read only = yes
create mask = 0755
Jakuje
  • 6,793
Lance C.
  • 101
