I just installed Ubuntu 16.04 LTS with an USB, and now when I turn on the computer(Lenovo ideapad Z460), I have options for Ubuntu and Windows 10. But when I choose Windows 10, it just comes back to the choice between Ubuntu and Windows. What should I do to be able to re-use Windows 10 system again ?
I updated GRUB several times but in vain, I tried to run the updated grub too. My windows system still does not boot.
I tried boot-repair, but it didn't work.
My boot-repair pastebin
Maybe the Windows system is damaged because I have chosen the 'Ubuntu and Windows co-existing" option?
ouyang@ouyang-Ideapad-Z460:~$ sudo fdisk -l [sudo] ouyang 的密码:
Disk /dev/sda: 465,8 GiB, 500107862016 bytes, 976773168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xc3ffc3ff
设备 启动 Start 末尾 扇区 Size Id 类型
/dev/sda1 * 63 443002096 443002034 211,2G 7 HPFS/NTFS/exFAT
/dev/sda2 443002878 976768064 533765187 254,5G f W95 扩展 (LBA)
/dev/sda5 675854613 976768064 300913452 143,5G 7 HPFS/NTFS/exFAT
/dev/sda6 443002880 671811583 228808704 109,1G 83 Linux
/dev/sda7 671813632 675854335 4040704 1,9G 82 Linux 交换 / Solaris
Partition table entries are not in disk order.
