I'm setting up a new Ubuntu Server (16.04) to which up to 50 people will have access at the same time. I've followed this tutorial to setup the XRDP with the xfce and every thing is fine so far, the problem is that only 10 users can be logged in at the same time. can anyone help about that. thank you.
Asked
Active
Viewed 3.4k times
You need to need to increase the default allowed connection using the
/etc/ssh/sshd_config
File, add the lines
MaxSessions 50
MaxStartups 50:30:100
to that file. Then restart you system.
Form man sshd_config(5):
MaxSessions
Specifies the maximum number of open shell, login or subsystem
(e.g. sftp) sessions permitted per network connection. Multiple
sessions may be established by clients that support connection
multiplexing. Setting MaxSessions to 1 will effectively disable
session multiplexing, whereas setting it to 0 will prevent all
shell, login and subsystem sessions while still permitting for-
warding. The default is 10.
MaxStartups
Specifies the maximum number of concurrent unauthenticated con-
nections to the SSH daemon. Additional connections will be
dropped until authentication succeeds or the LoginGraceTime
expires for a connection. The default is 10:30:100.
Alternatively, random early drop can be enabled by specifying the
three colon separated values ``start:rate:full'' (e.g.
"10:30:60"). sshd(8) will refuse connection attempts with a
probability of ``rate/100'' (30%) if there are currently
``start'' (10) unauthenticated connections. The probability
increases linearly and all connection attempts are refused if the
number of unauthenticated connections reaches ``full'' (60).
George Udosen
- 37,534
