13
I'm using Ubuntu 16.04. I recently started learning DevOps and got a bit crazy with my /etc/hosts and /etc/hostname files. In my frantic attempt to spin up a couple of servers from my local machine I lost track of the default settings, and was just curious to know what they are/were.
As I recall /etc/hosts and /etc/hostname had only one entry, which was the username of my local machine. However I'm not entirely sure.
By any chance does anyone know what the default settings are with a fresh install?
muru
  • 207,228
They are based on what you specified as the hostname when you installed: in my below examples "myhostname" is the name you chose. The defaults look a bit like this:
/etc/hostname
myhostname
/etc/hosts
127.0.0.1 localhost
127.0.1.1 myhostname
The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback ff02::1 ip6-allnodes ff02::2 ip6-allrouters
Note I don't put the domain part into /etc/hostname - opinion is divided on whether to do this but I've experienced server software that breaks if a FQDN is in /etc/hostname whereas I've so far had no issues caused by only the hostname there.
thomasrutter
  • 37,804
