How do you make Elasticsearch start at boot time on Ubuntu 16.04? I've installed elasticsearch from the standard repo with:
sudo apt-get install elasticsearch
and it works fine. However, I have to manually start it with:
sudo service elasticsearch start
after I login. I've tried the usually trick for configuring services to start at boot with:
sudo update-rc.d elasticsearch defaults
sudo update-rc.d elasticsearch enable
but that's done nothing.
$ systemctl status elasticsearch
* elasticsearch.service - Elasticsearch
Loaded: loaded (/usr/lib/systemd/system/elasticsearch.service; disabled; vendor preset: enabled)
Active: active (running) since Sun 2017-02-05 17:11:59 EST; 8h ago
Docs: http://www.elastic.co
Main PID: 9133 (java)
CGroup: /system.slice/elasticsearch.service
`-9133 /usr/bin/java -Xms2g -Xmx2g -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+DisableExplicitGC -XX:+AlwaysPreTouch -server -Xss1m -Djava.awt.headless=true -Dfile.encod
