After upgrading from Kubuntu 16.04 LTS to 16.10 the wired connection doesn't work. The wired connection is displayed in the Network Manager but is not possible to select the relative "Connect" button. The wi-fi connection is working.
The strange thing is that using a Kubuntu 16.10 live USB on the same PC the ethernet connection is immediately recognized and working.
These are some results :
*-network
description: Wireless interface
product: Wireless 7260
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlan0
version: 73
serial: a0:a8:cd:cc:e2:7d
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=4.8.0-37-generic firmware=17.352738.0 ip=192.168.178.32 latency=0 link=yes multic
ast=yes wireless=IEEE 802.11
resources: irq:93 memory:d0700000-d0701fff
*-network DISABLED
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: eth0
version: 0c
serial: c0:3f:d5:6d:86:9e
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonego
tiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full latency=0 link=no multicast=yes port=MII
speed=10Mbit/s
resources: irq:89 ioport:e000(size=256) memory:d0604000-d0604fff memory:d0600000-d0603fff
andrea@Sara-desktop:~$
[code]sudo ifconfig -a[/code]
eth0: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether c0:3f:d5:6d:86:9e txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Loopback locale)
RX packets 2060 bytes 181968 (181.9 KB)
TX packets 2060 bytes 181968 (181.9 KB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.178.32 netmask 255.255.255.0 broadcast 192.168.178.255
inet6 fe80::a2a8:cdff:fecc:e27d prefixlen 64 scopeid 0x20<link>
ether a0:a8:cd:cc:e2:7d txqueuelen 1000 (Ethernet)
RX packets 39431 bytes 53149953 (53.1 MB)
TX packets 11174 bytes 1144582 (1.1 MB)
ifconfig -a
RX packets 43498 bytes 2940360 (2.9 MB)
TX packets 43498 bytes 2940360 (2.9 MB)
wlan0: flags=4098<BROADCAST,MULTICAST> mtu 1500
Following some suggestions I loaded driver r8168 instead of r8169, without success. The PC is a NUC DN2820FYK.
Thanks in advance for your help.
This is the result of the suggested command :
dmesg | grep r8168
[ 1.614987] r8168: loading out-of-tree module taints kernel.
[ 1.615409] r8168: module verification failed: signature and/or required key missing - tainting kernel
[ 1.615988] r8168 Gigabit Ethernet driver 8.042.00-NAPI loaded
[ 1.637921] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.637930] r8168 Copyright (C) 2016 Realtek NIC software team <nicfae@realtek.com>
[ 1.722440] r8168 0000:03:00.0 enp3s0: renamed from eth0
