I need some help to get my wifi card working. I migrated from w7 to Ubuntu 16.04 LTS and my problem started.
My wireless card is enabled into BIOS settings, and I've already pressed Fn+F8 to turn it on.
When looking too lspci -knn i've got this:
02:00.0 Network controller [0280]: Intel Corporation Centrino Advanced-N 6230 [Rainbow Peak] [8086:0091] (rev 34)
Subsystem: Intel Corporation Centrino Advanced-N 6230 AGN [8086:5201]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Checking dmesg | grep iwlwifi i've found this message:
RF_KILL bit toggled to disable radio.
I suspect that this is a indicative o the problem I'm facing.
I've already tried to do some sequences such as:
rmmod iwldvm
rmmod iwlwifi
rfkill unblock all
modprobe iwlwifi
modprobe iwldvm
My 'rfkill list all' output is:
0: Toshiba Bluetooth: Bluetooth
    Soft blocked: no
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: yes
2: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
And finally for reference these are my loaded modules:
Module                  Size  Used by
rfcomm                 69632  0
bnep                   20480  2
btusb                  45056  0
btrtl                  16384  1 btusb
btbcm                  16384  1 btusb
btintel                16384  1 btusb
bluetooth             520192  29 bnep,btbcm,btrtl,btusb,rfcomm,btintel
uvcvideo               90112  0
videobuf2_vmalloc      16384  1 uvcvideo
videobuf2_memops       16384  1 videobuf2_vmalloc
videobuf2_v4l2         28672  1 uvcvideo
videobuf2_core         36864  2 uvcvideo,videobuf2_v4l2
v4l2_common            16384  1 videobuf2_v4l2
videodev              176128  4    uvcvideo,v4l2_common,videobuf2_core,videobuf2_v4l2
media                  24576  2 uvcvideo,videodev
arc4                   16384  2
iwldvm                233472  0
mac80211              737280  1 iwldvm
intel_rapl             20480  0
snd_hda_codec_hdmi     53248  1
x86_pkg_temp_thermal    16384  0
intel_powerclamp       16384  0
snd_hda_codec_realtek    86016  1
coretemp               16384  0
snd_hda_codec_generic    77824  1 snd_hda_codec_realtek
snd_hda_intel          40960  3
snd_hda_codec         135168  4     snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel
kvm_intel             172032  0
snd_hda_core           73728  5     snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
snd_hwdep              16384  1 snd_hda_codec
kvm                   540672  1 kvm_intel
snd_pcm               106496  4     snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_core
snd_seq_midi           16384  0
snd_seq_midi_event     16384  1 snd_seq_midi
iwlwifi               200704  1 iwldvm
snd_rawmidi            32768  1 snd_seq_midi
irqbypass              16384  1 kvm
snd_seq                69632  2 snd_seq_midi_event,snd_seq_midi
cfg80211              565248  3 iwlwifi,mac80211,iwldvm
snd_seq_device         16384  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              32768  2 snd_pcm,snd_seq
snd                    81920  17 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
lpc_ich                24576  0
mei_me                 36864  0
mei                    98304  1 mei_me
soundcore              16384  1 snd
joydev                 20480  0
input_leds             16384  0
shpchp                 36864  0
serio_raw              16384  0
toshiba_acpi           40960  0
sparse_keymap          16384  1 toshiba_acpi
wmi                    20480  1 toshiba_acpi
toshiba_bluetooth      16384  0
toshiba_haps           16384  0
mac_hid                16384  0
parport_pc             32768  0
ppdev                  20480  0
lp                     20480  0
parport                49152  3 lp,ppdev,parport_pc
autofs4                40960  2
jitterentropy_rng      16384  0
drbg                   32768  1
ansi_cprng             16384  0
algif_skcipher         20480  0
af_alg                 16384  1 algif_skcipher
dm_crypt               28672  2
crct10dif_pclmul       16384  0
crc32_pclmul           16384  0
ghash_clmulni_intel    16384  0
aesni_intel           167936  1127
i915                 1208320  3
aes_x86_64             20480  1 aesni_intel
lrw                    16384  1 aesni_intel
gf128mul               16384  1 lrw
glue_helper            16384  1 aesni_intel
ablk_helper            16384  1 aesni_intel
cryptd                 20480  566     ghash_clmulni_intel,aesni_intel,ablk_helper
i2c_algo_bit           16384  1 i915
drm_kms_helper        155648  1 i915
psmouse               131072  0
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
ahci                   36864  2
sysimgblt              16384  1 drm_kms_helper
fb_sys_fops            16384  1 drm_kms_helper
libahci                32768  1 ahci
e1000e                237568  0
drm                   364544  5 i915,drm_kms_helper
sdhci_pci              28672  0
sdhci                  45056  1 sdhci_pci
ptp                    20480  1 e1000e
pps_core               20480  1 ptp
video                  40960  2 i915,toshiba_acpi
fjes                   28672  0
This is my current kernel version:
Linux isengard 4.4.0-62-generic #83-Ubuntu SMP Wed Jan 18 14:10:15 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Thanks in advance!
Pilot6
  • 92,041
According to this page you can cycle through wifi and bluetooth with Fn+F8.
Can you try a solution mentioned here ?
The thing which solved my case was setting the wifi ON using hardware switch.
Try it: Boot into ubuntu in recovery mode and select enable networking
Reboot and all is done. I then had Hard blocked: no and my wifi started working
For more on this laptop see also here.
albert j
  • 1,463
