I am currently using Ubuntu 14.04 LTS on a laptop without any other OSs. Recently, my laptop started booting into the GRUB command line (note: note grub rescue> but just grub>). I tried following the steps here: https://www.linux.com/learn/how-rescue-non-booting-grub-2-linux , but got a little mixed up along the way. The second ls command (i.e. the one on the partition) doesn't return the expected output. Additionally, it shows two partitions, whereas I had maintained only a single partition. I suspect that this is because I encrypt my hard disk, which requires a passphrase unlock before I can boot the OS.
Therefore, I tried SuperGRUB2, mentioned at the bottom of the same page. However, despite following the instructions here: http://www.supergrubdisk.org/wizard-restore-grub-with-super-grub2-disk/ I am seeing the following output while trying to get into the "Super Grub2 Disk screen" (i.e. the screen that should show the "Detect any Operating System screen"):
Error 13: (http://grub4dos.chenall.net/e/13)
Invalid or unsupported executable format
Press any key to continue...
The URL mentioned in the error doesn't lead to an active page.
Any help would be tremendously appreciated. I have a lot of data saved on this laptop that I haven't backed up, and I've been in crisis mode for the past 3-4 hours!
Thank You
