Basically I've been using windows 10 on my hard disk (this is a laptop) and booting in kali linux with a usb stick from time to time, but since I realized I liked Linux a lot I decided to try a dual boot with Ubuntu (I have a backup just in case) possibly without wiping my data. So I made a live USB, booted into it and selected the 'install' option that appears on the desktop. I went with the 'dual boot with windows 10' option. I'm writing from Ubuntu from my main hard disk right now, but the problem is that from what I understood when I boot the 'black menu' (I think it's the grub bootloader or something like that) I should see an option to boot from windows, but I only have three options: Ubuntu, Advanced Ubuntu Settings (or something like that) and finally 'setup system' (once again, something like that). No Windows 10 option! As soon as I noticed it I installed GPARTED (I made some experience with kali) and I saw that windows is still there (could have done it with nautilus but due to being used to the crappy explorer in windows which can't even see freaking partitions I didn't think about it), so now if I'll have to reinstall Windows I can pass my old files which are still there with no problem (even though I'd prefer to resolve this with some faster solution), but even then, how can I keep both without ubuntu doing this? Any help will be appreciated, thanks in advance.
Edit: Fixed it! As @oldfred suggested I ran sudo update-grub and everything worked from then on.
Tommaso Thea
  • 319
  • 14
Installing Windows or any other operating system wouldn't remove Ubuntu unless you chose the Ubuntu partition for your install, and formatted the partition. Since you say you see Windows with GParted, then you know which partition to install Windows. You also can see which partitions have any of your other Operating systems.
Installing Windows would most wipe out Grub. So after you install Windows you will have to reinstall grub. This is easily done from the LiveUSB or LiveDVD disk and running the steps provided in this answer.
L. D. James
  • 25,444
sudo update-grub solved the problem.
Sangam
  • 101
