How can I enable Chinese character input in Kubuntu 16.10 on Plasma 5.8?
I found this answer but it seems quite old.
I can enable Chinese character input in Xubuntu 16.10 easily by installing ibus-pinyin and selecting Chinese options in Input Method (I have no language options in my Kubuntu):
sudo apt-get install ibus-pinyin
But how can I do that in Kubuntu?
I have this message on my Kubuntu when I launch Input Method:
Current configuration for the input method:
 * Active configuration: missing (normally missing)
 * Normal automatic choice: none (normally ibus or fcitx or uim)
 * Override rule: zh_CN,fcitx:zh_TW,fcitx:zh_HK,fcitx:zh_SG,fcitx:ja_JP,fcitx:ko_KR,fcitx:vi_VN,fcitx
 * Current override choice:  (en_GB)
 * Current automatic choice: none
 * Number of valid choices: 1 (normally 1)
The override rule is defined in /etc/default/im-config.
The configuration set by im-config is activated by re-starting X.
Explicit selection is not required to enable the automatic configuration, if the active one is default/auto/cjkv/missing.
Any ideas?
I can't find Language Support in my kubuntu 16.10 as well! why??
Run
  • 2,748
