I'm not able to access or open KDE connect indicator. Whereas kde connect monitor and kde connect settings are opening. What should I do?
nooneswarup
  • 135
Try unpair and start over, but make sure you request pair from the desktop app to the phone and not the other way around.
Also, verify that the phone is:
  • On
  • Connected to same WiFi as your Ubuntu device.
Otherwise, there could be something wrong. In this case you can consider reinstalling kde-connect as suggested by @ThisIsNotAnId:
sudo apt purge indicator-kdeconnect kdeconnect
sudo apt install indicator-kdeconnect kdeconnect
Liso
  • 15,677
Following our discussion in the comments, it seems you don't have the necessary repo on your system for indicator-kdeconnect. Run the following on a terminal:
sudo add-apt-repository ppa:vikoadi/ppa
sudo apt-get update
sudo apt-get install indicator-kdeconnect
Log out, log in. Open indicator applet.
===EDIT===
Open a terminal and run indicator-kdeconnect and post any messages, errors, warnings that the terminal gives in your question.
