I have installed ubuntu 15.04 and 14.04. First i had installed 14.04 after that i installed 15.04 and the grub boot menu changed to 15.04. Now i want to revert it, that means i want to change the grub that appears on startup to grub of 14.04. How to do it?
If you look in /etc/default/grub, you have a variable GRUB_DEFAULT:
↳ grep GRUB_DEFAULT /etc/default/grub
GRUB_DEFAULT=0
This is the menu entry that will be used by default. To see which menu entries you have, have a look in /boot/grub/grub.cfg (nl -v 0 is used to add the line numbers):
↳ egrep "^menuentry |^submenu " /boot/grub/grub.cfg | nl -v 0
0 menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-bf88b0d6-7f16-4314-87f5-ce3e84a6a396' {
1 submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-bf88b0d6-7f16-4314-87f5-ce3e84a6a396' {
2 menuentry 'System setup' $menuentry_id_option 'uefi-firmware' {
Having GRUB_DEFAULT=0 means booting the first menuentry. So if you wanted to boot to System setup by default (as a silly example), set GRUB_DEFAULT=2 and run sudo update-grub.
In the case you want to boot something in the submenu by default, you'd have to use the submenu index, > and the index of the menuentry in the submenu. E.g, 4th entry in submenu, then GRUB_DEFAULT should be set to "1>3"
It is also possible to set GRUB_DEFAULT to name label of a menuentry (first parameter), so GRUB_DEFAULT='System setup' would also be a valid setting.
Whenever changing /etc/default/grub, do not forget to run sudo update-grub.
More reading at https://help.ubuntu.com/community/Grub2/Submenus.
- 1,231
