On Lenovo N22 80S6 Ubuntu doesn't show on the boot menu after I "successfully installed" it. Here is the step-by-step of what I did:
(1)Downloaded Ubuntu 16.04.1 ISO, used YUMI to burn it to my 1TB seagate portable drive.
(2)Changed boot mode to Legacy Support and boot priority to Legacy First because I read that somewhere.
(3) Installed Ubuntu without trying live because on live, the installer got stuck on downloading package.
(4) I did not select "something else" but this is what that screen looks like. I'm only showing this because I feel like something's not right there.
(5) Then I got this message.
(6) After 10-15 min the installation was supposedly finished.
(7) Unplugged the USB and computer shut off. When I turned it on I got a boot menu with 2 choices: eMMC Disk Samsung 64GB and Windows Boot Manager. Hitting enter on either of those choices just brought me back to the boot menu. I no longer have Windows (that was my decision but now I wish I had saved it so I can give up on Ubuntu).
ankit7540
  • 4,195
Will M
your installation disk doesn't work. That's all. Try manually once. Press Do something else, delete the partitions, create new ones.
Option 1:
1st partition Format EXT4 path /
2nd partition Swap
or
Option 2:
1st partition Format EXT4 path / (at least 40.000mB)
2: Format EXT4 path /Boot (at least 500mB)
3: Format EXT4 path /Home (full size)
4: Format EXT4 path /tmp (at least 4000mb)
If manually installing it doesn't work either, make another usb disk using unetbootin which works 100%. You can boot into this live sessing , download ubuntu , in a terminal :
sudo apt install unetbootin
and use it to create a new bootable live session.
