Recently, when I booted my ubuntu partition, I recieved an Initramfs error. I followed the directions in this post:
Initramfs error during boot
However, when I ran the command:
sudo fsck /dev/sdb1
(As a side note, my ubuntu partition is on sdb) I recieved another error saying:
ext2fs_check_desc: Corrupt group descriptor: bad block for block bitmap
fsck.ext4: Group descriptors look bad... trying backup blocks...
Journal superblock has an unknown incompatible feature flag set.
Abort <y>?
I type no and the next thing says:
Journal superblock is corrupt
Fix<y>?
Next comes a series of y to fix this issue.
My question is this, is there a better method to fix a corrupt superblock? Or does this mean I need to reinstall ubuntu 14.04?
philm
  • 717
Let me offer you a solution I found:
  1. Reboot from a live CD
  2. Find out which partition we are dealing with"
    sudo fdisk -l
    # but in your case its sdd1
  3. Make sure its a superblock problem with:
    sudo fsck.ext4 -v /dev/xxx # in your case xxx => sdb
  4. Check for your super block backups location:
    sudo mke2fs -n /dev/xxx
    # Results:
    Superblock backups stored on blocks:
    32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
  5. Restore superblock from backup with and repeat till its fixed:
    sudo e2fsck -b block_number /dev/xxx
  6. If step 4 does not work repeat with next value in step 3
Source:
https://linuxexpresso.wordpress.com/2010/03/31/repair-a-broken-ext4-superblock-in-ubuntu/
https://ubuntuforums.org/archive/index.php/t-1245536.html
George Udosen
  • 37,534
