I've recently set up my Macbook Air (late 2010) to dual-boot OS 10.10 with Ubuntu 16.04, and of course along the way I've run into the black screen problem when using the proprietary NVIDIA drivers. I've just tried Andreas' fix here. It all seems to go swimmingly, except that when I get to step #4 to reboot and check, I don't get the correct result for the PCI-E register for the bridge device. This is what I get for step #2:
Bus info          Device     Class          Description
pci@0000:00:00.0             bridge         MCP89 HOST Bridge
pci@0000:00:03.0             bridge         MCP89 LPC Bridge
pci@0000:00:15.0             bridge         NVIDIA Corporation
pci@0000:00:17.0             bridge         MCP89 PCI Express Bridge
pci@0000:02:00.0             display        MCP89 [GeForce 320M]
I've created the grub script /etc/grub.d/01_enable_vga.conf as described:
cat << EOF
setpci -s "00:17.0" 3e.b=8
setpci -s "02:00.0" 04.b=7
EOF
...and also changed the permissions and updated grub...
~> sudo chmod 755 /etc/grub.d/01_enable_vga.conf
~> sudo update-grub
...but when I reboot the machine and check, the value for the bridge device is incorrect:
~> sudo setpci -s "00:17.0" 3e.b
00
~> sudo setpci -s "02:00.0" 04.b
07
Any suggestions on what I can do to get this set correctly before I install the NVIDIA drivers? Am I changing the wrong bridge device? Is there a better way to do this?
Thanks in advance!
Jiffy
I finally solved the problem when setpci doesn't change the value of PCI-E bridge.
If you are unable to set the value of PCI-E brigde registers using setpci command in order to get nVidia GeForce drivers working on your Apple MacBook machine try these steps:
1. Find your PCI-E bus identifiers
lshw -businfo -class bridge -class display
[root@kernelLinux]# lshw -businfo -class bridge -class display
You will need the ID's of PCI Express Bridge and your display in format XX:XX.X
Your ID's can be different.
In this example our ID's are 00:17.0 for PCI-E brige and 02:00.0 for display [GPU].
2. Create a GRUB script
Our script will be slightly different than in mentioned post above.
I have noticed of two things. Grub2 installed using distro (mine is Centos) installation process doesn't contain setpci grub module. It's the reason why grub do not change registers while boot. Then It is necessary to load setpci module into grub before we run commands to change registers.
Download grub2-efi-modules
Ubuntu Linux
sudo apt-get install grub-efi-amd64-bin
Fedora Linux
sudo dnf install grub2-efi-modules
CentOS Linux
sudo yum install grub2-efi-modules
Modules will be installed in /usr/lib/grub/x86_64-efi/ but the setpci module files needs to be present in /boot/efi/EFI/ubuntu/x86_64-efi/
Create x86_64-efi folder.
Ubuntu folder in /boot/EFI/ can be different on your machine depends how you named it in OS installation process, do not paste it. Replace it with correct path.
sudo mkdir /boot/EFI/ubuntu/x86_64-efi
Copy setpci module files into grub2 folder
sudo cp /usr/lib/grub/x86_64-efi/setpci.* /boot/EFI/ubuntu/x86_64-efi
Create the 01_enable_vga.conf file.
The file should contain these lines of code:
Do not forget replace 00:17.0 for PCI-bridge and 02:00.0 for display [GPU] with your values.
sudo nano /etc/grub.d/01_enable_vga.conf
cat << EOF
insmod setpci
EOF
Then repair permissions
and update the /boot/efi/EFI/ubuntu/grub.cfg
Ubuntu Linux
sudo update-grub
Do this command only on other distributions (not necessary on Ubuntu after update-grub):
grub2-mkconfig -o /boot/efi/EFI/centos/grub.cfg
3. Reboot your system and check registers
Reboot your machine and check if it's working. Replace ID's with yours again. Your terminal should finally show 08 (PCI-E bridge) and 07 (GPU).
08
07
4. Install nVidia drivers
Screenshot: https://i.sstatic.net/nim4Z.jpg
ylwghst
  • 59
I had the same problem and got here because of google. It seems both you and I were confused by the file /etc/grub.d/01_enable_vga.conf
You want to have the file contain the cat command, you don't want to create it with cat (well, you can create it with nested cat). So try this:
sudo bash -c "cat > /etc/grub.d/01_enable_vga.conf" << END
cat << EOF
EOF
END
I got the answer here: MacBook Pro 7,1 + Ubuntu 16.04 LTS + nVidia drivers
Sandy
