Let's say, I opened a terminal and entered / executed some shell commands.
But I didn't invoke explicitly Bash or any other shell.
What shell was used by default?
The one specified on your line in /etc/passwd (it is a : separated line and the shell is the final one).
For example mine:
chris:x:1000:1000:Chris,,,:/home/chris:/bin/bash
Here it is /bin/bash (the Ubuntu default)
You can also use chsh:
$ chsh
Password:
Changing the login shell for chris
Enter the new value, or press ENTER for the default
Login Shell [/bin/bash]:
This is telling me my shell is /bin/bash and letting me change it.
Finally, echo $SHELL will do the same:
$ echo $SHELL
/bin/bash
typing the following will display what shell the terminal opened with:
echo $SHELL
However, to find out what shell you are currently in (you may have changed it) type
ps -p $$
e.g. you will see that the shell is bash in the example output
PID TTY TIME CMD
3500 pts/0 00:00:01 bash
Another method is to use
echo $0
this will simply return the name of the current shell.
GNU Bash is the shell used by default in terminals on Ubuntu. However when scripts are executed on system boot then dash is used, as it is dash that is /bin/sh.
This is defined in the $SHELL environmental variable. You can check by typing echo $SHELL in the terminal.
By default it's bash:
env | grep ^SHELL=
In most cases will produce
SHELL=/bin/bash
To get file path of current shell executable one can use
readlink -f /proc/$$/exe
Some possible outputs are:
/bin/bash/usr/bin/bash/usr/bin/zsh/home/victor/.linuxbrew/Cellar/zsh/5.2/bin/zshEasiest way to check your terminal is by using pinky command:
pinky -l YourUsername
to change your default shell as the above answers already did, use chsh or manually edit /etc/passwd
