I recently installed and mounted a second hard drive. This second hard drive uses VMPlayer to run Windows. I am able to run VMPlayer, but only if I launch it with gksudo vmplayer.
It's clearly a permission issue that prevents me from running it from the menu icon. I tried modifying the folder permissions of /media/ssd by switching the root user and applying chown. The error Operation not permitted appears.
I also tried using gksudo nautilus, which (not surprisingly) gives me the same error message.
I don't believe it's relevant, but I'm getting these error messages upon launching nautilus.
(nautilus:6290): Gtk-WARNING **: Failed to register client:
GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name
org.gnome.SessionManager was not provided by any .service files
Initializing nautilus-dropbox 2015.10.28 ^C
root@osr-ubuntu1:/media/ssd# gksudo nautilus
(gksudo:6471): GConf-WARNING **: Client failed to connect to the D-BUS
daemon: Failed to connect to socket /tmp/dbus-m8iOpaGhDR: Connection
refused GConf Error: No D-BUS daemon running
(gksudo:6471): GConf-CRITICAL **: gconf_value_free: assertion 'value
!= NULL' failed
(nautilus:6476): Gtk-WARNING **: Failed to register client:
How can I change the directory permissions if even root isn't allowed to change it?
EDIT
I tried following the suggestion at External hard drive not allowing permission. When I run the line
sudo chattr +i immutable
I get the error
chattr: Inappropriate ioctl for device while reading flags on immutable
What does that mean?
This is not a duplicate of the NTFS/FAT32 question. My partition type is vfat.
Shaun Overton
  • 221
I solved the problem by remounting the hard drive. Zanna posted a thread that pointed me in the right direction. That thread's suggestion of changing fstab lead to a two hour nightmare where my machine wouldn't boot.
Once I discovered the relevant Ubuntu documentation, I was able to use this line for my vfat partition in /etc/fstab.
/dev/sda5 on /media/mynewdrive type vfat (rw,nosuid,nodev,uhelper=hal,shortname=mixed,uid=1000,utf8,umask=077,flush)
Shaun Overton
  • 221
