I'm a bit new to linux. using Ubuntu-16.04LTS. The terminal froze when i trip to open browser using terminal command. Browser name website (chromium-browser www.facebook.com) Terminal resumed after closing the browser Is there anything I need to know?
muru
  • 207,228
nooneswarup
  • 135
Yes .. That's the way it works. As long as a command is running in the terminal, it is blocked from doing other things. Think of chromium-browser as a long running process, just as sleep 60 or similar.
You can put it in the background, freeing your terminal prompt for other work, either by pressing ctrl-z to suspend the process, and then type bg %1 (or the number ctrl-z returned in [] if not 1) to let it run in background.
Or adding a & after the command when you start it:
sleep 60 &
This will send it in the background immediately.
Soren A
  • 7,191
