I'm trying to configure Redmine for Ubuntu 11.10, using this method Redmine for 11.10 but ran into some crazy snag somewhere with apache. Upon issuing service apache2 restart I get the following errors.
* Restarting web server apache2
ulimit: 88: error setting limit (Operation not permitted)
(13)Permission denied: make_sock: could not bind to address 0.0.0.0:80 no listening sockets available, shutting down
Unable to open logs
I haven't been able to make heads or tails of what exactly is going on with apache. I understand what ulimit does (monitor system wide resource allocation) but don't know why setting the limit would not be permitted?
Here's the contents of /etc/apache2/sites-available/default, were the root of the problem might be...
<VirtualHost *:80>
ServerAdmin jd@neongecko.com
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access.log combined
Alias /doc/ "/usr/share/doc/"
<Directory "/usr/share/doc/">
Options Indexes MultiViews FollowSymLinks
AllowOverride None
Order deny,allow
Deny from all
Allow from 127.0.0.0/255.0.0.0 ::1/128
</Directory>
# See
# http://www.modrails.com/documentation/Users%20guide%20Apache.html
# for details on what these options do. They will lead to an increase
# in memory usage, but significantly reduced access times.
# Speeds up spawn time tremendously -- if your app is compatible.
# RMagick seems to be incompatible with smart spawning
PassengerSpawnMethod smart
# Keep the application instances alive longer. Default is 300 (seconds)
PassengerPoolIdleTime 300
# Additionally keep a copy of the Rails framework in memory. If you're
# using multiple apps on the same version of Rails, this will speed up
# the creation of new RailsAppSpawners. This isn't necessary if you're
# only running one or 2 applications, or if your applications use
# different versions of Rails.
RailsFrameworkSpawnerIdleTime 0
# Just in case you're leaking memory, restart a listener
# after processing 5000 requests
PassengerMaxRequests 5000
# Only check for restart.txt et al up to once every 5 seconds,
# instead of once per processed request
PassengerStatThrottleRate 5
# Specify the minimum number of instances passenger can keep
# while cleaning idle instances
PassengerMinInstances 3
<Location /redmine>
Options Indexes -ExecCGI FollowSymLinks -MultiViews
# AllowOverride None
Order allow,deny
Allow from all
# mod_rails
# PassengerUser redmine
#RailsEnv edoceo_live
RailsBaseURI /redmine
# environment.rb
# Redmine::Utils::relative_url_root = "/redmine"
</Location>
</VirtualHost>
# Then after the virtualhost is loaded, send it a request
# to initialize the redmine installation
PassengerPreStart http://2222.us/redmine
EDIT I got the error log working through some fluke, here is the errors that I am receiving inside error.log, this might provide some insight.
[Wed Dec 14 12:06:09 2011] [notice] caught SIGTERM, shutting down
[Wed Dec 14 12:06:10 2011] [error] *** Passenger could not be initialized because of this error: Unable to start the Phusion Passenger watchdog because its executable (/usr/lib/phusion-passenger/agents/PassengerWatchdog) does not exist. This probably means that your Phusion Passenger installation is broken or incomplete, or that your 'PassengerRoot' directive is set to the wrong value. Please reinstall Phusion Passenger or fix your 'PassengerRoot' directive, whichever is applicable.
[Wed Dec 14 12:06:10 2011] [notice] Apache/2.2.20 (Ubuntu) Phusion_Passenger/3.0.11 PHP/5.3.6-13ubuntu3.2 with Suhosin-Patch configured -- resuming normal operations
