I've installed Ubuntu 16.04 and effectively lost control of my computer which worked just fine under Ubuntu 14.04. I just need a simple command line instruction(s) so I can save my files on my 2tb backup drive, reformat my hard drive and start all over again. Even though I don't want to use it I've even lost access to the partitions with Windows 7 on them.
Here's a few steps that you might want to do:
- Find a friend with a computer. Download Ubuntu 16.04 LTS installation
*.isofile, and create bootable USB using an utility of your choice for creating installation USB. Buy your friend a beer if necessary. - Insert the USB into the computer, boot and enter Boot Selection menu. Select to boot from USB. Usually this is F8 key, but it depends on your computer.
Once your computer boots to USB, choose "Try Ubuntu", press Ctrl-Alt-F1.
You will need to know which
/dev/device is your hard drive. Uselsblk -o NAME,FSTYPEfor that.ext4is Ubuntu ,ntfsis Windows - general rule of thumb. Here's my output example - primary solid state drive /dev/sda has Ubuntu on/dev/sda1, and secondary hard drive has whole bunch of Windows stuff:NAME FSTYPE sda └─sda1 ext4 sdb ├─sdb1 ntfs ├─sdb2 vfat ├─sdb3 ntfs ├─sdb4 ntfs ├─sdb5 ntfs └─sdb6 ext4Once you know which one is your Ubuntu, do the following (substitute
/dev/sda1with your actual paritition found in step 4)sudo mount /dev/sda1 /mnt sudo mount --bind /dev /mnt/dev sudo mount --bind /proc /mnt/proc sudo mount --bind /sys /mnt/sysAt this point you can either change password for your user to recover your system, or run
rsynccommand to copy files somewhere. Take a look at this for reference if you choose to copy files:Copy file to External Hard Disk If you choose to change password, dosudo passwd your_login_name
- 107,582
