When I type into command line sudo apt-get update I'm unable to complete all the update and I'm also unble to install any type of other software. The command line give to me this error
Some index files failed to download. They have been ignored, or old ones used instead.
The list of errors:
Err:29 http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial/main amd64 Packages
  404  Not Found
Err:37 http://ppa.launchpad.net/ubuntu-x-swat/x-updates/ubuntu xenial/main amd64 Packages
  404  Not Found
W: The repository 'http://ppa.launchpad.net/colingille/freshlight/ubuntu xenial Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'http://ppa.launchpad.net/ubuntu-x-swat/x-updates/ubuntu xenial Release' does not have a Release file.
E: Failed to fetch http://ppa.launchpad.net/colingille/freshlight/ubuntu/dists/xenial/main/binary-amd64/Packages  404  Not Found
E: Failed to fetch http://ppa.launchpad.net/ubuntu-x-swat/x-updates/ubuntu/dists/xenial/main/binary-amd64/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Can someone help me?
guntbert
  • 13,475
Remove these lines from your sources list files:
Have a look in the /etc/apt/sources.list.d/ folder and remove the corresponding files, and then run:
sudo apt-get update
again.
muru
  • 207,228
albert j
  • 1,463
For the errors:
  404  Not Found
  404  Not Found
It's because the authors have no xenial repository defined.
Change the first one from xenial to vivid.
Change the second one from xenial to trusty.
The easiest place to change this is by using Software & Updates, locate the failing ppas, and edit the repository name. Or, if you don't need them, just delete them.
heynnema
  • 73,649
