Kubuntu 16.10 Asus N750J
Hello, here repotyig problem. I try to update....:
sudo apt-get update
[sudo] password for user:
Get:1 http: //security.ubuntu.com/ubuntu yakkety-security InRelease [102 kB]
Hit:2 http: //ppa.launchpad.net/atareao/telegram/ubuntu yakkety InRelease
Hit:3 http: //de.archive.ubuntu.com/ubuntu yakkety InRelease
Hit:4 http: //repository.spotify.com stable InRelease
Hit:5 http: //de.archive.ubuntu.com/ubuntu yakkety-updates InRelease
Hit:6 http: //ppa.launchpad.net/wine/wine-builds/ubuntu yakkety InRelease
Hit:7 http: //de.archive.ubuntu.com/ubuntu yakkety-proposed InRelease
Hit:8 http: //download.virtualbox.org/virtualbox/debian yakkety InRelease
Fetched 102 kB in 1s (66.7 kB/s)
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
I try it and...
Setting up linux-headers-4.8.0-34-generic (4.8.0-34.36) ...
Examining /etc/kernel/header_postinst.d.
run-parts: executing /etc/kernel/header_postinst.d/dkms 4.8.0-34-generic /boot/vmlinuz-4.8.0-34-generic
when I do it this happen, and stay there forever, i try to close it and run another command and wont let me try another command, i have to restart the computer, also if i try to do it in a more grafic way like...:
software-properties-gtk
(software-properties-gtk:3628): Gtk-WARNING **: Locale not supported by C library.
        Using the fallback 'C' locale.
Cannot set locale: unsupported locale setting
(software-properties-gtk:3628): Gtk-WARNING **: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(software-properties-gtk:3628): Gtk-WARNING **: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(software-properties-gtk:3628): Gtk-WARNING **: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
(software-properties-gtk:3628): Gtk-WARNING **: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(software-properties-gtk:3628): Gtk-WARNING **: Theme directory aplets/64 of theme breeze-dark has no size field
(software-properties-gtk:3628): Gtk-CRITICAL **: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkNotebook
Opens the "software & updates" preferences and when you configure it and close it, it self update and shows a window:
The information about available software is out-of-date
To install software and updates from newly added or changed sources, you have to reload the information about available software.
You need a working internet connection to continue.
I click reload and shows:
and again.. stay there forever with out doing nothing
could you guys tell me some possible solution, im lost here.
build log in: /var/lib/dkms/nvidia-367/367.57/build/ :
Kbuild file: https://paste.ubuntu.com/23911754/
.log file: https://paste.ubuntu.com/23911773/
Xoktz
  • 13
  1. remove the Nvidia driver package with dpkg -r nvidia-367 (you must select other driver in order to uninstall)
  2. configure pending packages with dpkg --configure -a
  3. purged packages: How can you completely remove a package?
  4. update and upgrade: sudo apt-get update and sudo apt-get upgrade
Xoktz
  • 13
