15
I am horribly impatient and can't stand the (for me subjectively long) delay of around 2 seconds after entering an incorrect password in the login screen or also as sudo password, before I can retry typing it correctly.
Is there a way to modify the delay and reduce it to around half a second or turn it completely off, both for sudo and the login screen?
The optimal solution would include a longer delay after maybe 3 or 5 incorrect passwords, to still prevent brute-forcing.
PS: I am currently using vanilla Ubuntu 16.04 with Unity Desktop and lightdm.
muru
  • 207,228
Byte Commander
  • 110,243
In Ubuntu, to remove the delay for incorrect passwords in the terminal, edit the file common-auth found in the folder /etc/pam.d.
sudo nano /etc/pam.d/common-auth
Then add the string nodelay to the end of the line
auth    [success=1 default=ignore]      pam_unix.so nullok_secure
so that it says
auth    [success=1 default=ignore]      pam_unix.so nullok_secure nodelay
Then save the file with nano by pressing Ctrl+X, Y, Enter.
If you want to instead change the delay, first do the step above and remove the delay completely. Then add the following line to the same file before the line you altered above:
auth       optional     pam_faildelay.so  delay=500000
This will be the first uncommented line of the file. If you add this line after the first line you edited, then it won't work.
Now you can edit the delay value to whatever you want. I put a half second like you wanted.
If you want to lower the delay rather than disabling it altogether, edit /etc/pam.d/login:
sudoedit /etc/pam.d/login
Find the line that looks like:
auth       optional   pam_faildelay.so  delay=3000000
Change the number after delay= to a smaller value, as desired.
Note that the number is in microseconds, so 1000000 is 1 second.
Sources:
Pezo
  • 103
Eliah Kagan
  • 119,640
To get your system to ignore the default password security delay add nodelay to the /etc/pam.d/common-auth file:
Change this line:
To:
Then reboot the system for it to take effect.
Note:
Formerly done in /etc/login.defs, but now handled by PAM in the /etc/pam.d by various configuration files.
George Udosen
  • 37,534
