I installed Ubuntu 16.04.1 server version with my customized kernel. When booting, I see systemd-modules-load failed to start.
journalctl -xe error as below
-- Unit systemd-modules-load.service has begun starting up.
Jan 28 23:08:08 ubuntu systemd-modules-load[1278]: Failed to find module 'iscsi_tcp'
Jan 28 23:08:08 ubuntu systemd-modules-load[1278]: Failed to find module 'ib_iser'
Jan 28 23:08:08 ubuntu systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Jan 28 23:08:08 ubuntu systemd[1]: Failed to start Load Kernel Modules.
-- Subject: Unit systemd-modules-load.service has failed
As the log mentioned, iscsi_tcp and ib_iser are failing to be loaded. However I cannot find where iscsi_tcp and ib_iser are defined.
man modules-load.d list below 3 paths:
   /etc/modules-load.d/*.conf
   /run/modules-load.d/*.conf
   /usr/lib/modules-load.d/*.conf
The existing one is /etc/modules-load.d/modules.conf, and it's empty. Where are iscsi_tcp and ib_iser defined?
Zanna
  • 72,312
CSJ
  • 153
You need to edit /lib/modules-load.d/open-iscsi.conf:
nano /lib/modules-load.d/open-iscsi.conf
change from ib_iser to #ib_iser
F3 key followed by Enter key to save change, Ctrl+X to exit nano
To start services ...
systemctl restart systemd-modules-load.service
To check ...
systemctl status systemd-modules-load.service
Zanna
  • 72,312
igpetru
  • 106
