I am trying to install a theme in Ubuntu 16.10 and I am getting error on sudo apt-get update it shows:
awahab@awahab:~$ sudo apt-get update
[sudo] password for awahab:
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
muru
  • 207,228
You probably have some kind of program that locks the APT files. This could be:
  • Ubuntu software center installing something
  • You changing your software sources
  • The Software Update doing it's work
If you reboot the machine and issue that same command, what does happen?
fedecupe
  • 551
What this means is that another process is already using sudo. This could be any program that asked for a password when you opened it. Close all other programs and try again. If that doesn't work, reboot your computer and only open the terminal and run this command again.
