27
I am trying to get my hands on some JSON file validators.
I came across jq but after running jq . file.json I only got JSON formatted output, not a validation of the JSON in my file.
I want to know how I can check the syntax or validate JSON format in my file in Ubuntu. Please advise!
Zanna
  • 72,312
Try jsonlint:
sudo apt install jsonlint
The basic usage syntax is
jsonlint YOUR-FILE.JSON
You find its manual by typing man jsonlint or visiting its online manpage:
An excerpt:
NAME
       jsonlint - A JSON syntax validator and formatter tool
SYNOPSIS
       jsonlint [-v][-s|-S][-f|-F][-ecodec]inputfile.json...
OPTIONS
       The  return  status  will  be  0 if the file is legal JSON, or non-zero
       otherwise.  Use -v to see the warning details.
       -v, --verbose
              Show details of lint checking
       -s, --strict
              Be strict in what is considered legal JSON (the default)
       -S, --nonstrict
              Be loose in what is considered legal JSON
       -f, --format
              Reformat the JSON (if legal) to stdout
So you can see whether your JSON is valid by checking the return code of jsonlint. You can see it by running echo $? right afterwards (0=OK, 1=invalid), or by evaluating it using &&, || or if.
Byte Commander
  • 110,243
11
I tried jsonlint but it doesn't work.
jq . may-file.json work nice!
Hope this feedback is helpful.
zatamine
  • 564
You can do this using python json.tool module
echo '{"name": "dedunu", "country": "LKA"}' | python -m json.tool
If you have a file you can use it as below.
python -m json.tool file.json
But the problem with this command is that you won't get a detail about the problem in JSON file. I found the answer from this link.
dedunu
  • 9,556
jq will spit out the error explicitly, and you can also check the exit status, which is 1 for parse errors, and obviously 0 for successes.
For example:
% jq '.' <<<'{"foo": "spam", "bar": 1}'
  "bar": 1,
  "foo": "spam"
% echo $?
Now, let's replace : with = after "bar"-- making the input an invalid json:
% jq '.' <<<'{"foo": "spam", "bar"= 1}'
parse error: Invalid numeric literal at line 1, column 23
% echo $?
heemayl
  • 93,925
