I deleted my partition for windows 8.1 and also the image file installing Ubuntu. What I wanted to do was install Ubuntu alongside Windows using half my disk space. Is there any possible way to recover windows 8.1 other than purchasing it?
*First installed OEM installer then regular version also tryin to install and run some iso files on my system
Zanna
  • 72,312
Noelle Q
A great free and open source software that I always recommend to anyone for recovering lost partitions is TestDisk
There are several methods available to use TestDisk to recover your partitions. Just choose the one you find more appropriate for you from the webpage TestDisk Livecd
In addition the website also contains a step by step guide in order to help you.
Lastly don't forget that the more you use a drive after accidental deletion, the less likely you are going to be able to recover from it!
Good luck :)
dmr_helper
  • 376
When this happens shutdown and do not install or use any software.
  1. Start a live CD or live usb stick of ubuntu,etc.
  2. Download testdisk using live CD.
  3. Install testdisk from a terminal session ie sudo ./testdisk (terminal can be found in the start menu)
This is taken from unallocated-space-with-important-data/24951#24951
Testdisk can be downloaded from; http://www.cgsecurity.org/wiki/TestDisk_Download
For instructions on how to use testdisk see; http://www.cgsecurity.org/wiki/TestDisk
Good Luck.
user647201
