In order to use an USB-Stick encrypted with Bitlocker I installed Dislocker on my Ubuntu 16.04 according to Use (Windows) BitLocker-encrypted drive on Ubuntu 14.04 LTS.
Unfortunately I cannot decrypt:
  • sudo fdisk -l lists 4 Partitions even though there is only one partition on the USB-stick. And the size is wrong too. (The Disks Utility shows also only one partition.
  • sudo dislocker -r -V /dev/sdb4 -uMyPassword -- /media/bitlocker does not mount any of the 4 listed partitions
I fixed it using the command
sudo dislocker -r -V /dev/sdb -uMyPassword -- /media/bitlocker
(no number after /dev/sdb)
When I try this, everything goes fine until I try to enter the mount folder. Then the following error shows up:
The chosen directory /media/bitlocker is not a valid
If you are running in the same problem, you will have to mount the file dislocker-file inside the folder with something like this:
mount -ro loop dislocker-file /media/bitlocker-mount/
+Don't forget to mkdir a new folder to mount to.
Thomas
  • 6,433
