On Jan 20, I embarked on a mission of installing or adding Ubuntu to my windows 10 resident operating system. When I was installing, it gave me options what I wanted. I opted for both windows 10 and Ubuntu along. I finished installing Ubuntu. But Windows 10 disappeared 100%, no trace of it.
But I continued to use the Ubuntu. My external hard drive was working fine day one of Ubuntu. But the next day, it did not show up on the menu as usual. Apparently, I did take out or unplugged the EHDD without permission from Ubuntu. Someone told me Ubuntu does not like EHDD being pulled out without permission? I am not sure if that is the cause of not able to detect WD My Passport Ultra EHDD.
However I have tried many attempts to do remounting the devices from the cli or CLIT or command line interface terminal. But nothing is working so far. I am not able to see any file. If I lose my data, it will be a big disaster. I also run Ubuntu smart test, and I did run all those tests. The tests nothing wrong with device. I also tried different computers with windows 10, 7 and they could not anymore detect it. I can only access the device from device manager in windows 10 and 7.
I did enter dmesg. I got this error as output:
[ 3.212657] sd 6:0:0:0: [sdb] Write Protect is off
[ 3.212660] sd 6:0:0:0: [sdb] Mode Sense: 53 00 10 08
[ 3.213956] sd 6:0:0:0: [sdb] No Caching mode page found
[ 3.213959] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 3.215583] scsi 6:0:0:1: Wrong diagnostic page; asked for 1 got 0
[ 3.215596] scsi 6:0:0:1: Failed to get diagnostic page 0xffffffea
[ 3.215603] scsi 6:0:0:1: Failed to bind enclosure -19
[ 3.215639] ses 6:0:0:1: Attached Enclosure device
[ 8.184127] sdb: sdb1
[ 8.189221] sd 6:0:0:0: [sdb] Attached SCSI disk
[ 8.352638] random: nonblocking pool is initialized
[ 32.994999] NET: Registered protocol family 38
[ 85.349681] EXT4-fs (dm-1): mounted filesystem with ordered data mode.
and this is the result of lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:16 0 931.5G 0 disk
└─sda1 8:17 0 128M 0 part
sr0 11:0 1 1.4G 0 rom
Is there anyone who had similar problem, and had the experience first hand and solved a problem like this? Your help will be appreciated.
