I was tweaking the mate panel trying to solve some other problem, when I changed the panel settings, from GNOME2, to something else. all my panel apps disappeared. Suspicious of that happening, I clicked the save button, before hand, but now I don't know how to restore my panel apps, there is no button for that.
From Zanna's comment, it would appear I am missing a feature of Mate Tweak. I don't see the panel option anywhere. This might be why I cannot restore my save. https://i.sstatic.net/Pz6sh.jpg
j0h
  • 15,365
This is a surprising and unnatural behavior of mate-tweak -- you want to "tweak" your settings, but instead you lose all of your prior customizations.
To avoid loss when using the Interface tab, it is critical that the first action you take is to click Save Panel Layout.
After that, if something outrageous happens, you should be able to restore by selecting the Custom option from the drop-down that is immediately above Save Panel Layout.
Underlying this behavior, it seems, is the wildly incorrect notion by mate-tweak that it is the only tool that will be used to configure your panels.
Had the same issue and found an easier workaround:
  1. install dconf-editor
  2. launch dconf-editor
  3. go into org > mate > panel > general
  4. the values in bold are the ones changed by mate-tweak: select each one of them and then "Set to default" in the bottom right corner
  5. restart for good measure and never touch mate-tweak ever again
harabat
I found my panels MISSING after using this tool. Opening them by using superkey +T and typing Mate-tweak, re-opened the tool. Then, there was only the options gnome 2 or OpenSuse (no "custom" or anything.. who knows where the one I saved went..) closing that. No panels. opened again. SELECTED icon size for menu items. Panels magically re-appear. try save again. No panels. Re-open tweak.. select icon size for panel icons. Menus magically re-appear. How frustrating. Now I remember why I don't normally use Mate. (XFCE4 guy here, where it's easy to save several panel configs, and the panels don't just go away..)
