Ok I had some boot issues which I managed to solved by reinstalling ubuntu on my primary disk (sda) before reaching to that point I used a program called boot repair (https://help.ubuntu.com/community/Boot-Repair)
Which didnt fix my problem in fact it made it worse (prior of using boot repair I could choose from grub the linux kernel and boot but I just couldnt log into my account because it was accepting it and throwing me again on the login screen after blacking out for a second anyway) after using bootrepair I couldnt even see grub... my computer looped in loading the bios screen and then restarting..
Boot repair did an other thing that I noticed only after I reinstalled ubuntu on my primary disk SDA.
I had a secondary disk (sdb) which had a windows installation (which I dont care if I can save or not) but also had a lot of personal data and documents!!! and it doesnt appear on ubuntu at all... using gparted I see that SDB has a red exclamation point and the entire disk is labeled as unallocated space!!!! (500GB of it)
I am 100% I never saw a formating process happening in the console nor did I see on any part of bootrepairs process SDB being mentioned! (It only purged and reinstalled kernel and grub on SDA!)
I could remove it from my computer and try to use a usb external drive hub to test if i can see its contents but before I go to such trouble is there anything else I can do?
I suspect that the data is intact and only some messy stuff happened to a few bits in the hard drives flag...
Please help the content of that drive is important to me.
papajo
  • 3,087
